Virtual Light Projection
  • Virtual Light Projection
    I want to throw a texture map as a light source onto the surface of another object. The same way physical projectors are used to do projection mapping onto buildings.
    What is a logical VRay approach to achieving virtual light projection. Would it be just using a standard vray light with directional on 1?
    -Joel E
    https://www.biglittlepictures.com
    use a standard max spotlight set to rectangular. faster and simpler.
      Okay, that was my conclusion as well, didn't know if there was a better way that had benefits I wasn't aware of..
      -Joel E
