Direct light visible in reflections while computing irradiance map.
  • Direct light visible in reflections while computing irradiance map.
    Hi!
    Just wondering why the direct light is visible in reflections while calculating an irradiance map? Not that it is any problem. just curious.
    /Tobias
    Originally posted by animator75 View Post
    Hi!
    /Tobias
    Probably you have enabled Store with Irr. map for some of the light sources in the scene or Show direct light in the GI settings.
    Tashko Zashev | chaos.com
      Thanks for the speedy answer! I don't have show direct light active, so it is probably the Store with Irr. map option that is active for the Vray Sun. I will let this rendering run it's course then have a look. Thanks!
