old vs new
Color mapping when resetting V-Ray goes back to LWF.
Perhaps your old scene was set up differently?
Copying the CM settings over (use vray presets!) will fix look differences.Lele
emanuele.lecchi@chaos.com
Disclaimer:
I'm really happy with how V-Ray keeps progressing. I Just want to understand what I'm doing wrong. I get the simplification of the new approach but on a base level if i try it, the image take twice as long to render (I understand that there is far less tweaking of materials subdivs) and looks crappier.
ok...here we go...
I will keep it simple as possible
1) fire up 3ds Max 2016 the V-Ray warning comes up and I select NO
2) merge in data and setup my old "recipe" for quick tests
- 1280x720
- no GI environment
- primary set it IR low
- secondary set to LC 400
- exposure control set to physical camera EV 12
render time 1:43
reset Max
1) fire up 3ds Max 2016 the V-Ray warning comes up and I select YES
2) merge in data
3) set exposure control to physical camera EV 12
4) reset V-Ray by selecting scanline and then V-Ray again (I thought selecting YES at beginning would have V-Ray already "reset"?)
5) change to bucket
6) change to 1280x720
render time 3:51
Link to zip file with all the goods if you need them https://www.dropbox.com/sh/3zyrw1quq...Q9q112b7a?dl=0
Originally posted by pixelplume View Postit stayed Reinhard when I reset...maybe I'm not understanding something...
The only certainty is if you know you do NOT touch any of the colormapping values, usually, so between 3.2 and 3.4 nothing changed there.
- 1280x720
- no GI environment
What you see is correct, reset VRay, re-set your GI to match the old settings.
You're just unused to this accuracy in occlusion between geo and lighting, which of course will always be slower than the settings you're using above, no question about it.
You can render the images, and save them in the VFB, then compare settings directly from there.Lele
Disclaimer:
Thanks for the quick reply!
No warning comes up simply starting max. Are you opening a scene, there?
I understand the my "old way" is not the best looking...splotchy
now to shift this thread to.....Brute force..... I have always been a IR/LC person. Should I pursue using brute force (loaded question I know) in interiors (what I mostly do).
If I leave it on Brute force the scene gets darker and the alcoves are less defined...
The reason I ask is that I teach design visualization to interior design students at the School of Visual Arts once a semester. I have been teaching the same class for almost 10 years. The workflow being is taking AutoCAD plans and elevations. Modeling them in Max, texturing & lighting in V-Ray (years ago I did mental Ray), and a little Photoshop. It's a TON for the kids to take in (I'm going to refrain from bitching about lazy millennials) during a semester. In the past I have given them a render preset that is good enough for their needs. Lately since the V-Ray toolbar came out I'm trying to get them to use the quick settings from there. This new approach is great since I don't have to explain subdivs. I just don't know If i should switch to IR/LC in lieu of Brute force.
as I typed this I clicked the quick settings interior button for fun and noticed it does not use the 1/24 preset any more and no brute force....Is this by design?
The problem is not with old/new vray versions.... You have your vray lights using "Store with Irradiance map" but are using Brute Force when you reset which is a no-no. Uncheck that on all your lights and the results are pretty much identical (other than the GI quality).www.dpict3d.com - "That's a very nice rendering, Dave. I think you've improved a great deal." - HAL9000... At least I have one fan.
thanks for doing this, i'm still without a working maxLele
Disclaimer:
Originally posted by pixelplume View Postnow to shift this thread to.....Brute force..... I have always been a IR/LC person. Should I pursue using brute force (loaded question I know) in interiors (what I mostly do).
http://forums.chaosgroup.com/showthr...image-with-SP3
(so no worries, EVEN millennials will be able to get the simple process!)
and here, for the IRMap:
http://forums.chaosgroup.com/showthr...307#post677307Lele
Disclaimer:
