Naturally i was pissed off by the render times of ies lights. So i started to fool around with them and normal lights to see if i could fake it. I setup a spot light and an ies in the same location and had the spot turned off. i only used it as a camera point to look at the image the ies light made on the ground. this i saved as an hdri then i loaded it into the projector slot of the spot light.
IES light
Spot Light Multiplyer = 1 HDRI Multiplyer = 1
Spot Light Multiplyer = 2 HDRI Multiplyer = 1
Spot Light Multiplyer = 3 HDRI Multiplyer = 5
Spot Light Multiplyer = 1 HDRI Multipley = 40
So it seems the closer you get to looking like the IES light it seems you cant escape the render time. Best solution however was to use a lower light multiplyer and higher HDRI multiplyer
IES light
