can someone help me with tweaking and explaning the Vray2SidedMtl for my Leaves. (A Max 2017 / 2018-File with my textures is attached)
The only Tutorial i found was this one:
http://www.peterguthrie.net/blog/200...torial-leaves/
But this didn't helped me very well.
As a starting point I used a sample tree from Evermotion: (SAMPLE TREE)
AM176_017
https://evermotion.org/shop/show_pro...-vol-176/13518
What I can not understand is why I have to use a Map for the Translucent slot in the Front Material. If I disconnect this Map I get a grey Back Material. But why????
![](https://forums.chaosgroup.com/filedata/fetch?filedataid=38951&type=thumb)
Just to understand that I am on the right track: (for the vray2sidedmtl)
When a light (the Sun) hit the leave, the leave will be transparent. But in shadow areas the leaves will show the front/back Material (depending if you look from top or bottom)
Perhaps some one give me some hints.
Thanks in advance
Carsten
AM176_017
Thanks in advance
Carsten
