Hi Chaosgroup,
I want to learn more about the intensity of the sun and different parts of the sky.
I read here: https://docs.chaosgroup.com/display/...em+%7C+VRaySun but there are quite many links that is old now.
I've used Gutries recent skys for a while now https://www.pg-skies.net/collections/recent-hdr-skies but realised that I have to know a bit more about the intensity relationship between the sun and the sky a clear day. I get nice result from his HDRis but want to learn more.
The second reference would be good to read from the Vray Sun Sky docs page but it's not availible ([2] R. H. B. Exell, The intensity of solar radiation, 2000 )
First I thought I should do my own not so scientific test that would consist of taking photographs with a 600mm equivalent lens with spot meter set in camera and ofcourse with some Solar ND filter infront of the lens, they often reduce the sun about 16-18 stops with that i could meter the sun sort of.
I understand that its very complicated stuff, but if every value I start with in the render is 90% right I'am happy, have no clue if the latest PGskies are anyware close to correct in terms of intensity values between sun and sky, I get realy nice result with his 1714 hdri thougt.
Won't write any longer that this for now
but a link where I can read further about the intensity of the sun and sky would be superb.
Further thoughts I have is choosing right exposure to start with when building materials from that later after a sun and sky system is decided in the scene, and also a bit about colormapping.
Right now my workflow is based on these:
http://www.peterguthrie.net/blog/201...hting-tutorial
http://www.peterguthrie.net/blog/201...-for-interiors
Best Regards
Karl Allemyr
Best Regards
Karl Allemyr
