What is the correlation between degrees of Anisotropic Rotation and the input color?
  • What is the correlation between degrees of Anisotropic Rotation and the input color?
    Hi Guys
    I have a question about placing maps into the Anisotropic slots of a V-Ray Material.
    I put a Vray color into the Anisotropic rotation to see how greyscale values correlate to a rotational value.
    I didn't understand the results I was seeing - Is it possible to Chaos to explain what Grey scale value correlates to the degree of rotation?
    Or maybe there can be an update the V-Ray Material for remapping to something more artist friendly. Like black = 0 Degrees and white = 360 degrees
    gradient white to black shows direction.
    Marcin Piotrowski
    youtube
    CGI OCIO config 04
      From the VRay documentation (https://docs.chaosgroup.com/display/...al+%7C+VRayMtl)
      Rotation - Determines the orientation of the anisotropic effect in a float value between 0 and 1 (where 0 is 0 degrees and 1 is 360 degrees).
      Software:
      Windows 7 Ultimate x64 SP1
      3ds Max 2016 SP4
      V-Ray Adv 3.60.04
      Hardware:
      Intel Core i7-4930K @ 3.40 GHz
      NVIDIA GeForce GTX 780 (4096MB RAM)
      64GB RAM
      DxDiag
        Thanks guys - sorry I should have read the documentation
          It should always be the first adress to look at when not understanding stuff with VRay. But we're all guilty of forgetting this once in a while
          Software:
          3ds Max 2016 SP4
          V-Ray Adv 3.60.04
          Hardware:
          64GB RAM
          DxDiag
