Material Starting Point
  • Material Starting Point
    Is there anyway to dictate where the material begins its pattern creation? If you look at the white brick in the attached image you can see the soldier and stacked brick are aligned properly, so how can I adjust this accordingly?
    If the (Revit) material hatch is set to model lines, you can select lines and move/align. This should adjust the starting point of the (V-Ray) material shader.
    Hardware: Intel i9 9900k - 32 GB RAM - NVIDIA Quadro RTX 4000 & i7 10875H - 32GB RAM - NVIDIA GeForce RTX 3070
      That actually worked, why did I never think of that. Thank you!
