Heya Matt!
It's a command line program with no user interface so you won't get anything appearing and staying open. You browse to whatever folder the maketx files are in from your command line and then run it with whatever options you want. Sharktacos on the forum has a guide here, hit the "click to show command line usage" button - https://docs.sharktacos.com/texture/mipmap.html
I thiiiiiiink what you can also do is take an image that you want to convert to tx and drag it on to the maketx.exe file in window explorer and it'll auto convert. You won't get a choice over some of the options though and I'm not sure if it's smart enough to put the converted file back into the same folder as the original non-tx texture.
