Single VRayMtl with object diffuse based on object's wirecolor
  • Single VRayMtl with object diffuse based on object's wirecolor
    Hi Guys
    Here's something simple I put together. It will let you render multiple object's wirecolor as diffuse, running of just a single VRayMtl
    1) Add a single "VRayMtl" to all your objects
    2) In the diffuse slot, stick a "VRayUserColor"
    3) In the Attribute name, add "diffuse_col_from_wire"
    don't add the quotation marks as part of the attribute name, just the name
    4) Select all the objects you want the script to affect
    5) Run this script:
    Code:
    for obj in selection do
        dcfw = (color (obj.wirecolor.r/255)(obj.wirecolor.g/255)(obj.wirecolor.b/255))
        setUserProp obj "\ndiffuse_col_from_wire" ((dcfw.r as string) + "," + (dcfw.g as string) + "," + (dcfw.b as string))
    click Render and have fun
    Kind Regards,
    Morne
    This might be useful, thanks for sharing!
      Here's an example of how to change vraytoon color per object, based on wirecolor, and a single vraytoon element
      https://forums.chaosgroup.com/forum/...18#post1114018
      Kind Regards,
      Morne
