How to get better VRay renders (aka working in linear space)
  • How to get better VRay renders (aka working in linear space)
    Hey everyone,
    I have done a little tutorial on working in linear color space in VRay 1.46.xx
    http://throb.net/site_main/LinearWorkflow.html
    Basically it shows you what's been wrong with many apps for a long time and how to get all that dark stuff OUT of your renders and create more photographically accurate imagery.
    let me know what you think
    rob
    throb
    vfx supervisor
    http://throb.net
    very informative Rob ... thanks
    Natty
    http://www.rendertime.co.uk
      Tkx Rob, good tut
      -dave
      Cheers,
      -dave
      â–  ASUS ROG STRIX X399-E - 1950X â–  ASUS ROG STRIX X399-E - 2990WX â–  ASUS PRIME X399 - 2990WX â–  GIGABYTE AORUS X399 - 2990WX â–  ASUS Maximus Extreme XI with i9-9900k â–
        very useful
        wish I had max 7 though
          That color correction is done on an image that is greater than 24-bit right?
          Otherwise, you could do it post, no?
          Also, can the Vray frame buffer with its corrections be used with backburner?
            it's the same thing as using max's logarithmic exposure control, no?
            i like the simple max interface with preview so i use it instead of manual curve editing or color mapping.
            Marc Lorenz
            ___ ___ ___ ___ ___ ___ ___ ___ ___ ___ ___ ___
            www.marclorenz.com
            www.facebook.com/marclorenzvisualization
              1) the image in the vray vfb is floating point. i turn off the clamping colors option. I will udate my docs to reflect that
              2) you don't do it in post. you only do it to your viewing system. this means the vray vfb and whatever post app you use (nuke, shake, fusion, etc)
              3) you do NOT burn in the curve. backburner doesn't care about the vfb settings. yes! i have successfully run hundreds of processors with this workflow in mind.
              throb
              vfx supervisor
              http://throb.net
                it's not the exact same.
                if we ask nicely, maybe the vray crew can add an 'apply inverse srgb' curve option to their vfb
                vlado? peter?
                throb
                vfx supervisor
                http://throb.net
                  Good info. Where does your .64 value come from?
                    it comes from looking at an sRGB correction curve and eye matching some numbers.
                    once the vray gods place the sRGB stuff properly into the vfb it will be a thing of the past.
                    throb
                    vfx supervisor
                    http://throb.net
                      hmmm...it's nice to know this trick but I got problems with colors with this method. Let's say client gives me some color chart in RGB. So I put this RGB number in material diffuse and when rendering with linearized method colors are washed out.
                      Luke Szeflinski
                      :: www.lukx.com cgi
                        I would suggest putting the color in and then usin ghte sampling tool in the vray VFB (right click) to make sure the color is actually right.
                        i have done that in the past and for the first sample i show on the page.
                        throb
                        vfx supervisor
                        http://throb.net
                          Awesome tutorial, I've been playing with this method today and love it!
                          Thanks for sharing.
                          Chris
                          The Revitlution
                            In Sony Vegas there is a preset in the Color Correction that says convert Computer RGB to Studio RGB. I've been using it allot lately. Anyone know if this is the same as sRGB? I couldn't determine from the links.
                            Thanks much throb
                            I see you got a link on maxunderground.com
                            --Jon
                              --Jon
                              Initially (I don't have Vegas) I don't believe that's the same thing.
                              Doesn't sound like it anyway.
                              What do the docs tell you?
                              rob
                              throb
                              vfx supervisor
                              http://throb.net
