Vrmat and dif bump directory
  • Vrmat and dif bump directory
    Hi, I have a question about vrmat directories and dif / bump locations. Our vrmat are created on one computer then exported for use on others. Our problem is that the address of the dif / bump is no longer good when we put the vrmat in the directory of Vray. What we would like is to store the dif / bump in a remote directory because in the directory c: it takes a lot of space and it is much less easy to save Do you have a solution for that?
    Thank you very much.
    Apologies for the late reply. You can move all assets used in your projects to any accessible location of your choice and then use the Extensions > V-Ray > File Path Editor to repath all files. For more info, please visit https://docs.chaosgroup.com/display/...le+Path+Editor
    Regards,
    Ana
    Ana Nedyalkova
    V-Ray for SketchUp | V-Ray for Rhino | QA
    www.chaosgroup.com
