Tips for converting materials between CPU and GPU
  • Tips for converting materials between CPU and GPU
    Hi All, I thought I'd collect some "things I learned" about setting up GPU materials, and welcome other's knowledge here too.
    First item to share is how to link a bump/normal map - because named UV mapping isn't working in GPU. Change the mapping to manual and add a "channel" node to select the number of the UV channel. (Default is "0") Also, "color" to "normal" seems to be the best place to connect the texture to the material.
    I learned that the first two color correct node options don't work with GPU, only the 3rd option
      ** EDIT: Layered node Seems to be working fine.
      The "Layered" texture node does not work. I end up using "blend" nodes a lot, but would like to know if there's a good way to layer materials in GPU. Does anyone know?
        For some meshes, especially when you are adding bump mapping, quads don't render correctly in GPU. Add a triangulation modifier to your mesh to render correctly.
          Thanks Andy all of those tips.
          Win11 Pro 64bit, GTX 970, Standalone version: V-Ray Next 4.30.03,
            You're welcome! I hope others can add their tips as well.
