Particle age
  • Particle age
    Hi. Is anyone familiar how to control particle age similar to cycles? Thanks.
    Could you please explain in more details what exactly you would like to achieve?
    V-Ray for Blender currently doesn't support Particle Age.
      i want them change color with time so when they getting older color is changing. I found sampler node (im trying to use it with remap node) which has a lot of outputs but no documentation which output is doing what. One of the outputs self explanatory like velocity (which is working fine) but i found between them "Frame time" output which could be instead of "age" but no luck. PS. Motion blur working with particles only some times. Basically it works 2 times out of 5, And what about Particle texture and Point particle?
        Hey can you please upload a scene where the motion blur doesn't work?
          poseidon4o on some frames it works on some no render at all, when i tweak MB settings it doesn't work at all just render particles as it is. Speed of particle remains constant.
          Dropbox is a free service that lets you bring your photos, docs, and videos anywhere and share them easily. Never email yourself a file again!
