Vray clouds question
  • Vray clouds question
    In this scene, I was wondering how to make the effect of the clouds evaporating and reforming like in this video. I know how to animate the gizmo containing the clouds. This was using vrayenvironmental fog atmospheric effect. Thanks in advance.
    I can't seem to be able to get to the file.
    However, take a look here, two of the noises have Flow (i.e. a 4th dimension) and may perhaps be used to animate interesting effects with some creativity.
    The result, you could plug into the density of a fog shader (f.e. volumeScatter, envFog, and so on).
    Lele
    emanuele.lecchi@chaos.com
    Disclaimer:
      Thanks Lele,
      I've contacted the forums about the file. I will repost the file when I hear back from them. Thanks.
        There is a problem with the link downloads from Chrome right now and our IT's will try to fix it. But you should be able to take the archive file using different browsers, Edge, Firefox,..
        Tashko Zashev | chaos.com
          Uploading the same files in .zip format.
            And now in .rar format.
              Indeed Chrome doesn't work well with .rar files - it might be a good idea to use .zip format instead.
