Trick: no alpha output per dome light ***
  • Trick: no alpha output per dome light ***
    since it's not possible to disable the alpha output anymore I was looking for a way to get my rendering saved without alpha, so that the background is visible and not transparent. My trick is to add a dome light for blocking the alpha only, it can be set to the needed backround color or texture. It helps me a lot not to remove the alpha from the saved PNG again and again.
    -Micha
    PS: I will post some of my tricks from time to time and mark it with *** so they can be found later again per search function.
