Wet Pavment Shader
  • Wet Pavment Shader
    Does some one have a good Max Vray shader of a wet surface with puddles of water that can be applied to outside items to make it look as if it just rained ( Ex.-Asphalt-Pavers-Concrete)? Im struggling to get one that looks convincing. Would you mind sharing it?
    Thanks
    https://www.turbosquid.com/3d-models...3d-max/1074037
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
      Thanks Bobby! Is this the one you use in your renderings? Yours all ways look so good!
        It’s just a matter of painting a good glossiness map to control certain areas or puddle edges or a grunge map.
        https://www.turbosquid.com/3d-models...streets/891930
        https://www.artstation.com/damaggio
          You're Welcome! No, I don't use that one, but I own it. Later today I can get you the one I use.
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            Bobby that would be awesome! Also go to my store and if you see anything you would want let me know and it's yours!
            https://www.cgtrader.com/profile/models
              44$ for a few noise maps in a blend material? lol no thanks its not 2004 that's a rip off....turboquid is so overpriced
              you could also try try quixel mixer or substance alchemist
                If it'd take you longer than $44 of hourly wages to produce an identical or better result on your own, it's a fair exchange for a professional asset. Might be worth it for some.
                __
                https://surfaceimperfections.com/
                  I've shared this couple of years back and I think it's still holding well in some cases
                  https://forums.chaosgroup.com/forum/...152#post742152
                  Simply, I love to put pixels together! Sounds easy right : ))
                  Sketchbook-1 /Sketchbook-2 / Behance / Facebook
