help: 360° virtual staging
  • help: 360° virtual staging
    Dear Community,
    is there working and proven workflow how we could add a furniture in a 360° photo of a space so it look convincing?
    The virtual staging with normal photo is clear, but how you are dealing with a 360° Panorama background?
    Should i map the panorama on a sphere and try to add the furniture manually? Some vertical edges are very distorted so...Or maybe generate 6 Cubemaps with KR Pano and then try to map a Box with them and add the furniture there?
    Thanks for your tips! They will be highly appreciated!
    Express Your Imagination - let it MAX!!!
    www.3dkad.de
    Maybe what you are looking for is quite simple - you need a wrapper material ground plane and your spherical panorama (long-lat) as environment. If you don't get shadows than try a dome light instead the simple environment.
    At this old tutorial you can see like it should be looking. The object create a transparent shadow at the wrapper ground and the panorama is be used as background and light source.
    https://www.youtube.com/watch?v=PlO1z6JMR9Y
      One hint more - if you look for a solution to shot high res panos than the XPhase could be interesting for you - a 16k one shot camera.
