Smoke die on contact
  • Smoke die on contact
    Hello is there a way to make smoke die on contact with TyFlow particles (objects)?
    Or a way to make an object build up from smoke?
    I currently have an object that builds up from TyFlow but then the emitters turn to smoke and the object is now basically smoke, which is not quite what I want.
    Maybe someone knows a tutorial in this direction or can give tips.
    Thanks a lot
    You could check out redefinefx.
