Light cache settings examples
  • Light cache settings examples
    We have added some examples of the effect of some light cache parameters to the help index:
    http://www.chaosgroup.com/support/pr...lightcache.htm
    We will add more examples soon.
    thanks again Vlado!
    It's very easy to understand with good example .
    Laurent
      Vlado we cant find the page anymore. Its not on the new support.
        Hmm, I can see it there... try to refresh the help index page.
          It doenst show up but with a mix of copy/pasting it does.....
          thnx !
            Can't open scene example
            I have tried several times but when I download the example scene for the walk through animation it doesn't open. I the first scene opened fine but this one fails. I tried 7.5 and 6 but with no luck. Has anybody else been able to open it ?
              you could have simply placed your concerns over ont being able to open the file in the appropriate topic about that turorial. i dont see why you need to post it in this unrelated topic as well as posting a new topic about it. a new topic should be for posting about a new tutorial or trick or tip you have for us.
                huh?
                  Chill out
                  Jesus chill out - I just figured it out - it was an .rar file - windows wasn't showing up an extension - you could have posted that Fanboy instead of jumping down my throat
                    sorry was a little crabby when i posted that. its just that ive been noticing alot all over the forum people posting things either more than once or in the wrng places. it just makes things hard to follow some times. i guess it was those 4 people who just before my posting here had messaged me on msn with concerns about vray...and they were taking the term "vray free" loosely. sorry about snapping at ya dude. i like to try to help people out on here usually but sometimes its those "other" people who tend to make us grabby.
                      Thanks for the apology - I know your posts and have used your help lots of times. I shouldn't have made the second post and deleted it shortly after I made it, I was just itching to do the tutorial and as the first scene downloaded without any hassle I was frustrated at not being able to open the second one. I am sort of stressed out myself, working on getting Deadline software set-up across a big network and have a consultant crawling through my files quizzing my file structure ect. puts me under more pressure then usual so I sort of panicked hence the dual post thing.
                      Keep up the good work with the forum Vray wouldn't be the same without this place
                        Hi Vlado... since you´ve changed to new chaos group web that tutorial links don`t work.
                        www.plan9-net.com
                          This one should work:
