hologram/neon like shader please
  • hologram/neon like shader please
    Just like in the topic. I was trying to create something like this but without visual success and I cannot find such tutorial/mat on the Internet. Any help most welcome!
    Best Regards
    Tomek
    Portfolio: http://dtown.pl/
    Got an example of something?
      I was thinking about something like this
      Best Regards
      Tomek
        Fairly easy, you can do it with a light material or with a regular vray material with self illumination. You can find a scene attached to this post with 2 materials in the slate editor, the vraymaterial is the one applied to the plane. Feel free to analyze and experiment. If you have any questions or requests just ask.
        A.
        www.digitaltwins.be
          Ok, I thought it might be that sort of thing.
          This is pretty quick, fairly dirty but the sort of idea I had in mind, if you wanted to do it in the render.
          Just a mix of simple gradient ramps with lens effects/blur and a blend for the guy's model.
          I could argue that it's easier done in post and a bit more controllable but it really depends on what sort of shot it is, animation or still etc.
            ok, thank you guys!
            Best Regards
            Tomek
              So as I thought, the example you posted used pretty much exactly the same technique as I used, with a (although blender) tutorial here, if it's useful https://index.artstation.com/artwork/1nKRXG
