4 INSANE methods of customizing 3ds Max UI, and the smart one.
  • 4 INSANE methods of customizing 3ds Max UI, and the smart one.
    Hey.
    Michał here from CG BBQ YT chanel.
    A new video about customizing 3ds Max UI for archviz is coming!
    We published it some time ago on GarageFarm.NET Academy, but an updated version is going to appear on the CG BBQ channel devoted only to 3ds Max tutorials.
    Unfortunately, I went crazy in the process of making the remake.
    See you soon!
    Cheers
    Matt
    GarageFarm.NET - The Cheapest Render Farm - 20,000 cores and growing!
    Xesktop - Powerful GPU servers for rental
    3DBee.IT - 3D asset store with integrated application
    Hey.
    We published the final tutorial video. Hope you will find it useful.
    18 steps to customize 3ds MAX UI for archviz projects
    In this tut, Andrew shows how to customize 3ds Max for modeling architecture.
    You will learn how to get rid of useless panels taking away precious workspace. Hotkeys and quick buttons will speed up your workflow. Other settings will help you manage your scene and work with the precision required in archviz.
    Finally, you will learn how to save your setting so you can switch between various UI setups and move them to a different 3ds Max installation!
    Timestamps:
    00:00 - Introduction
    00:09 - Setting up System Unit Scale
    01:39 - Setting up Display Unit Scale
    02:13 - Adding Hotkeys for Views
    04:18 - Adding Hotkey for Measure Distance tool
    04:39 - Adding Hotkey for Convert to Editable Poly
    05:09 - Setting up Snaps
    05:34 - Changing default Reference Coordinate System setup
    05:56 - Customizing Toolbars and Panels
    06:21 - Turning off the ViewCube
    06:25 - Adding Layer Explorer
    06:31 - Adding quick buttons for Modifiers
    07:04 - Locking UI layout
    07:25 - Adding more scene Undos
    07:43 - Extending Auto Backup interval
    08:01 - Turning on automatic Cross/Window selection
    08:38 - Expanding Command Panel
    09:10 - Turning off Preview Highlights
    09:27 - Changing the Vertex size
    09:44 - Saving customizations
    09:52 - ENU folder
    10:03 - maxstart.max scene
    10:20 - Quickly reverting to default settings
    10:58 - UI customization saving options in 3ds Max
    11:07 - Saving workspaces
    11:36 - saving UI from Customize - Save Custom UI scheme
    11:56 - Custom Defaults Switcher
    12:17 - Summary
    12:32 - Custom settings paths in 3ds Max
    12:39 - Useful Hotkeys
    See you in the next one!
    Cheers
    Matt
      Thx Matt. I already did most of the things you suggested in the video, which is indeed a very nice way of customizing max. Only one thing I failed to incorporate over the years was the option to put the Ref. Coordinate System to constant in the preferences. Somehow I missed this option. Thx for the tip it annoyed me so much, but not enough to look up the solution .
      A.
      www.digitaltwins.be
        Hi Vizioen.
        Thank you for the feedback, I'm happy you found the vid useful.
        Yep, that annoyed me as well. Years of microseconds spend on clicking on the coordinate system add up to a full weekend. But it's also about having a good flow during work.
        Cheers
        Matt
