Vray Light not showing in layers
  • Vray Light not showing in layers
    Good morning.
    When i create a light it does not show in the layers?
    Why not?
    Also
    when i group a light with the object I have built to set the light in, and use Forest pro to scatter it on a line, I can not adjust the light if I group it with the object, and then scatter and un group the parent light , all the scattered lights disappear.
    How do I get around this issue?
    Thank you
    phil
    Hi, your thread is not for this section. Here we discuss only V-Ray for 3ds Max related topics. I will move your thread to the Chaos Common section
    The Light does not appear in the scene explorer because you have disabled it from the filters:
    You can open the group and move the light but you can not ungroup. Probably Itoo could give you more details about this behaviour of Forest Pack.
    Vladimir Krastev | chaos.com
      Thank you . In groups when using lights you have to open the group with e drop down command OPEN RECURSIVELY.....make the change then close.
      There is still so much of Max and Vray I do not know, after 15 years........ is there a good certified course you would do yourself that you would recommend?
      Thank you again
      Phil
