I have tried to make the spectrum effect in three renders rgb and composit them together later this is all fine except I don't get a linear spectrum but rather spotted is there a way to fake this in a better way?
chromatic spectrum in a diamond
can you post the seperate layers and final mix to show what you mean by spotted?
can we see the splits too? i had an idea on how to get the diamond done, can you tell me how to make a diamon? i know its not just a faced sphere.
im thinking maybe if you had mask for the diamond. (black and white) then also had 3 passes on the diamond each using a sliiiiightly different IOR. then in photoshop for each layer you delete two color channels so that you have a red diamond, a blue one then a red one. then use additive blending you would be able to combine the colors to regrain your white and only the areas that differ would show the coloring thus giving you your color spectrum in those areas. then mask the diamond so you can place it on your background...beats me if it would work but it sounds plausable.
well, what else did you expect? If you have real diffraction, it depends on the amount of samples if you get a transition or spots like you have here. Basically what you have done is rendering 'three samples' (without randomization) hence the three spots.
edit: I mean dispersion, not diffractionYou can contact StudioGijs for 3D visualization and 3D modeling related services and on-site training.
the only way I can think of is using more samples, thus more different color renderings. I think the best is to render all different layers in only one color light, for example all in red, and only change the IOR between renderings, then re-color each resulting 'channel' in photoshop by adjusting the hue for every rendering. The more you come near to endless amount of channels, the more it will come near to reality.You can contact StudioGijs for 3D visualization and 3D modeling related services and on-site training.
Indeed, pretty clever.You can contact StudioGijs for 3D visualization and 3D modeling related services and on-site training.
all i did was use IOR 2.47 and had the diamond set to diffuse color black refraction color 255 blue, then rendered that. altered the IOR to 2.57 then rendered with refraction color Green then changed IOR again to 2.67 and made it Red. these colors i mixed in AE with the blue on bottom set to blending mode normal, then red and green ontop both set to blending mode lighten, i found blending mode add was way too bright.
Originally posted by Da_elfall i did was use IOR 2.47 and had the diamond set to diffuse color black refraction color 255 blue, then rendered that. altered the IOR to 2.57 then rendered with refraction color Green then changed IOR again to 2.67 and made it Red. these colors i mixed in AE with the blue on bottom set to blending mode normal, then red and green ontop both set to blending mode lighten, i found blending mode add was way too bright.Daniel Westlund
