multi object scatter?
  • multi object scatter?
    hi !
    is it possible to scatter multiple objects over one surface?
    f.e. several kinds of trees, stones over a terrain?
    regards
    S.Wolf
    yup. get the scatter plugin at www.maxplugins.de You can scatter multiple objects at the same time and even input distribution weights.
      Hey stephan have you seen my file?
      Laurent
        You can use Pflow......
        -----Dwayne D. Ellis-----
          hehe! that what I said!!
          Laurent
            does pflow ship with max 5.1?
            regards
            S.Wolf
              @percy: the script from p watje?
              regards
              S.Wolf
                regards
                S.Wolf
                Nope. PFlow shows up in Max 6
                  time for an update..
                    regards
                    S.Wolf
                    yes
                      Percy:
                      Mate, do you have that blur plugin for rotation and scale etc that you used for your trees. I cant find it on the net anywhere. and the blurlib while your at it so i can actually use the plugin
                        ooohhh damn. should have caught me while I was still at work. I dont have it at home. If you dont find it by monday let me know.
                          dah.... damn.. hehehe
                          Ok, i have had a pretty damn good dig around already a week or so ago. But will look again. Will let ya know.
                          Tanks.
                            isn't scatter built into max?
                            Needs more cowbell
                            • #15
                              not like this scatter....
