DR tutorial?? tips?
  • DR tutorial?? tips?
    I want to setup DR with some other computers in the office. Is there a tutorial or step by step guide to set this up? Thanks in advance for any suggestions.
    Regards Peter.
    Check this out:
    http://www.spot3d.com/vray/help/VRay..._rendering.htm
    nikki Candelero
    .:: FREE Your MINDs, LIVE Your IDEAS ::.
      Thanks Candelaro - will do. I also found the Installing DR for 3dsmax 4.x... posted by Vlado - I am using VIZ 2005, which is Max 6, wondered if this was a MAX 4 specific post - Vlado??
      Will check out that post now Candelero - thanks again.
      Regards Peter.
        Candelero - thanks man
        looks like I'm in the right direction. I'll keep you posted on my progress. Any suggestions or tips from experienced DR users is greatly appreciated.
        Using VIZ 2005 with Vray 1.47.03, on main machine - Dual Xeon 2.8, and trying to set up on new Dell Dimension 5150 for DR - OS is XP Pro on both machines - bitmaps are local on both with Maxfile on the server, different machine.
        Regards Peter.
          Here's a problem -
          I made up a vrayspawner.ini file with the path as laid out in that link, see above. When I start the vrayspawner60.exe it looks like VIZ starts up goes down to the task bar and then closes suddenly and starts again and just keeps cycling like that.
          I checked the task manager and it keeps opening and then closing. What could be the problem?? Vlado?? Thanks for any help.
          Regards Peter.
