Originally posted by mike.edel
Quoting: "Above, both 4:1:1 and 4:2:0 sampling methods have been mentioned. The former means that both of the chroma difference signals (Cr and Cb) are sampled at one quarter of the luminance sampling rate. The latter, on the other hand, uses half the luma sample rate for the colour differences, but the two differences are only sampled on alternating lines (resembling SECAM). Both give the same total data rate, but the 4:2:0 sampling gives a better apparent colour resolution for PAL.
In the NTSC world, all three DV variants use 4:1:1 sampling. In the PAL versions, DV and DVCAM revert to 4:2:0, whereas DVCPRO uses 4:1:1 globally. Here's a catch - if you dub between PAL DVCPRO and one of the other formats, you'll end up with the worst from both worlds: a 4:1:0 sampled image, where both vertical and horizontal colour resolutions are only half of the conventional broadcast quality 4:2:2 sampling."
And yeah, having a huge studio does help with pulling good keys. And tracking points would help to more spectacular shots, and motion control cranes, and professional monitors, and pretty models and and....lots of cash
