OK, so what were your render settings out of Max? Are we talking 1080i or 1080p?
HD Animations - How too?
Kind Regards,
Richard Birket
http://www.blinkimage.com
We're doing more and more work in HD as well and it's a killer. Our frame rendertimes are about the same as previously mentioned, sometimes more. Some shots from Ford "Ice" took up to 10-12 hours / frame. You can afford this if you have enough cores and if the sequence is short. But generally, these are NOT production friendly rendertimes. Ford "Rollercoaster" was also done in HD but because of the graphic nature of it, the rendertimes were not bad - just the size of the images. Fills up 1TB really quickly.
Ford "Ice"
HD is moving much faster into the mainstream than anticipated so many of my friends' studios are playing the catch-up game along with the rest of the world...
-Richard
Originally posted by tricky View PostOe you charging more to do HD?Patrick Macdonald
Lighting TD : http://reformstudios.com Developer of "Mission Control", the spreadsheet editor for 3ds Max http://reformstudios.com/mission-control-for-3ds-max/
Originally posted by re:FORM View PostThat's quite a scary question! I hope everyone is charging extra for the massive increase in technology required, modelling, texturing, rendering, compositing, etc If people try to absorb it in their normal workflow then we're all effectively taking a massive paycut.
