VrayDirt and reflexions in Vray 1.5
  • VrayDirt and reflexions in Vray 1.5
    Hello,
    i have a simple Vraymtl grey with a reflexion at 255 255 255
    i want to add dirt with a VrayDirt material (a Mix in the diffuse channel) and remove the reflexion only on the dirt area.
    When i use the VrayDirt material in the reflexion channel, i never manage to get what i want.
    Can you help me ?
    Grégory Chevalier
    - Web : http://www.cg3d.org/ -
    yeah, the vray dirt doesn't work that way. Youll have to separate out the reflection pass and do what you want in post.
      Hello Gregory,
      You can take a look at this scene:
      Scene file is here: http://www.spot3d.com/vray/images/dirt/refl_dirt.rar
        ummm... maybe i stand corrected.
          a Vraydirt in a Mix (with an output to control) ! this is the key
          it seems to work perfectly (except in Bucket mode)
          Thank you very much Mr Vlado
          Grégory Chevalier
            haha thats cool.
            Thought it should work
              I imagine it will work the other way around as well? That would be great to make reflection limited to a small area
              You can contact StudioGijs for 3D visualization and 3D modeling related services and on-site training.
                Ive been playing with this a lot today.
                From one of my tests I ended up with a material that had about 20 layers of shaders/maps in
                8 minute render time to do a chamfered cube, but it was one hell of a cube.
                Customising your main textures to use under dirtmasks is fantastic.
                  Now this cube you speak of... I simply must see it
                    Not the cube in question, but much more practical results.
                    Those textures used are usually incredibly flat and boring on their own
                      hahaha works rather well
                        That image seems particularly dirty.... even the advertisments on you your host page are particularly... "Dirty"
                          Sorry, I'd heard about imageshack having spyware and didnt know of any others to use. Last time i used paintedover it was google ads
                          Its not porn though, its just a bit tasteless.
