de-stabilized physical camera
  • de-stabilized physical camera
    you can add a small amount of noise to the target of the physicalCamera and turn on motionblur.
    This renders an image without an stabilized lens.
    The amount of wigglyness is controlled by the shutter speed.
    Georg
    In Polygongewittern - Industrial Parametrisation of the World
    http://www.preset.de/
    http://www.count-as-one.net/
    ooo, cool idea
    and welcome to the forum!
    Eric Boer
    Dev
      Sounds cool, but i don't understand... Add noise to the physical camera target?
      "Why can't I build a dirigible with my mind?"
        i assume he means add a position list controller and then add a noise controller...
        Thorsten
          Thorsten is right:
          Add a "positions list" to the camera_target.position and a Noise controller to the empty slot.
          here are some samples:
          the same frame with different settings:
          Georg
            Re: de-stabilized physical camera
            and by the noise shape and scale too.
            good trick, and welcome
            Lele
              Nice method, but i prefer adding a rotation noise controller to the camera itself.. gives basically the same results but works with non - targeted cameras, what i usually use. good values are angles of about 0.5°.
              Of course you got to do a liitle "rig" for that by parenting the camera to a dummy, or as i often do, to an istanced cam without shake
              This signature is only a temporary solution
