From time to time we`re doing a shadow study on our projects.
Right now my method is as follows:
- set up the Max Daylight system to my location and desired date
- animate the sun form morning 7:00 to evening 17:00 every 15-30 minutes
- then I postprocess the images in Premiere adding hour labels onto each image
BTW - in this process I have a problem using the Max`s Sun - it`s a direct light always set to a very high values - around 40 and I can`t get Vray to render a proper, unburnt image. My trick around this is to turn off the MaxSun and attach a new Direct light with Vray shadows to the MaxSun (Max sun being an animation controller), this way I get well lit renders.
Question is - do you have any tricks on how to do this more efficient or better? (for example to make Max stamp the hour names on the rendered images?) Is there a way to use Vray Sun system to animate correct sun/shadow study rendering? Maybe some smart plugin 4 that?
Please share some of your Gr8 wisdom!
Thanks!
Thanks!
