switching from crt 2 tft. lwf ?
  • switching from crt 2 tft. lwf ?
    hi,
    i am switching from ctr 2 tft soon.
    curently i am using a crt @ 2.2 gama and lwf.
    must i forget all abaout lwf i used in the past and
    go the "old way" in vray with tfts?
    thx a lot.
    blue
    max 9 + vray
    No, you can work it the same way. Just buy a Spyder and calibrate your new monitor to 2.2.
    Tim Nelson
    timnelson3d.com
      yep and good luck
      Laurent
        ok. thank you very much.
        max 9 + vray
          Originally posted by priad
          yep and good luck
          ha ha nice one
          Chris Jackson
          Shiftmedia
          www.shiftmedia.sydney
            yep and good luck
            ha ha nice one
            WHy?
            Tim Nelson
            timnelson3d.com
              hey, is LWF a LightWaveFile ?
              Lele
                Lele
                lwo
                LightWaveObject? (i think)
                  When buying a new tft make sure it has both calvine presets and rgb settings , that way it will callibrate the best way if using the spyder 2pro, if you only have rgb and no calvin presets its gona be much harder to set it.
                  http://www.3dvision.co.il
                    ähm, must say i dont know. it will be a benq gp, prosumer midway i think. they are just ordered but i will tell you, when they arive.
                    but i think they might be srgb only
                    max 9 + vray
                      LWF = Linear Workflow
                      Colin Senner
                        r u sure?
                        Nuno de Castro
                        www.ene-digital.com
                        nuno@ene-digital.com
                        00351 917593145
                          london winter fall
                            Light the Way Forward!
                            Lele
