PSD manager
  • PSD manager
    Hi all
    if you have some problems with PSD MANAGER + under VFB : your psd file is empty (have empty layers!) - 3dsmax7/VRAY1.5(rc2) >>>
    1. check COMMON>RENDER OUTPUT> check: save your file *.file format
    2.if you have WARNING MESSAGE:
    warning: V-Ray VFB is enabled; 3dsmax render output file will be ignored.
    warning: To remove this warning, please disable either the 3dsmax save render output option or the V-Ray VFB.
    > after start rendering > stop render and UNCHECK: COMMON>RENDER OUTPUT> check: save your file *.file format
    after render save your image *.file format
    ARCHITECTURAL VISUALIZATION
    www.projects3d.com
