sandwave (patterns)?
  • sandwave (patterns)?
    hi friends
    anyone some ideas how to make sandwaves like this?
    for using as displacement?
    i've tried with ps,but my results are bad
    thanks
    http://fizyka.phys.put.poznan.pl/~pi...waves%2010.jpg
    I did something kind of similar I guess, but it was for a wall pattern. You need to use the pen tool & paths in Photoshop so you can make the curves nice & smooth. Here is the displacement map I made and what a render of it looks like.
    Tim Nelson
    timnelson3d.com
      I opened your ref. image in crazybump and it did a pretty good job of it.
      http://www.crazybump.com/
      This is with default settings, I just clicked 'analise for the 3d shapes' and then rendered the displacement map from it.
      Make that image tile and and use displacement with the normal for best results.
        @timmatron...thanks fot the tip,but how can i draw the paths with the pen in ps??
        @cubiclegangster..thanks,i will try it out!
          It basically works similar to how you create spines in Max. Using the pen tool, you select points and create lines and curves with it. Then you can adjust those points with bezier handles. When you get a shape you are happy with, you can stroke a brush along the path to create the actual layer that you can then start as a base for your displacement map.
          Tim Nelson
          timnelson3d.com
            many thanks for your help!
              No problem. Looking forward to seeing what you do with it.
              Tim Nelson
              timnelson3d.com
                i was totally going to steal that displacement map until I looked who posted it
                  What now that you know I did it, it's suddenly not good enough for you??? :P
                  Tim Nelson
                  timnelson3d.com
                    lol no, ill just see if I can find it on the maps drive
                      cubiclegangster: Great link. I have never seen this software before. Nice post.
                      timmatron: That's a really nice displacement map. And thanks for the tip on how to create such maps in photoshop.
