rgb values and LWF
    I agree with Dan, its the same as I do it. Although a script that helps would be nice!?
      I've always done it the way DanBrew does it - i thought this was the intension of this feature.
        I get the same result without all of the extra steps :
        1. Set the VRayColor to Specify, Gamma to 2.2, then input your RGB value. Just leave this in the diffuse slot, top level or not.
        If you use the other method for more than one color in a session, you will have to set the Gamma back to 1.0 before putting in your next RGB value. This is because it seems that the VRayColor map is smart and will make the .4545 adjustment to all existing VRayColor maps as well as any subsequently created...which leads me to believe that it has further use than as a simple color calculator.
        Ben Steinert
        pb2ae.com
          I just tried this again as it definitely did not work in the past, the specify value would not return up the stack. it appears this is working in the latest release, happy days.
          Maxer here is the script, I don't remember where I got it from.
          fn calculate_gamma inColSpn outColSpn gammaVal = (
          outColSpn.color.r = 255.0 * ((inColSpn.color.r/ 255.0) ^ gammaVal)
          outColSpn.color.g = 255.0 * ((inColSpn.color.g/ 255.0) ^ gammaVal)
          outColSpn.color.b = 255.0 * ((inColSpn.color.b/ 255.0) ^ gammaVal)
          rollout gamma_corrector "Gamma Color Corrector" width:340 height:40
          colorPicker cp1 "Pick RGB" pos:[8,8] height:24 fieldWidth:48 colorrange modal:false
          spinner spn1 "Gamma" pos:[110,12] height:16 range:[0,100,2.2] fieldwidth:48
          colorPicker cp2 "Corrected RGB" pos:[210,8] height:24 enabled:true fieldWidth:48 modal:false
          on gamma_corrector open do
          calculate_gamma cp1 cp2 spn1.value
          on cp1 changed col do
          on spn1 changed val do
          on cp2 changed col do
          createdialog gamma_corrector
          Richard De Souza
          www.themanoeuvre.com
            very interesting thread. thanks for the ideas and scripts.
            best regards
            themaxxer
            Pixelschmiede GmbH
            www.pixelschmiede.ch
            • #21
              Originally posted by gilpo
              I wrote this little app to do just what your asking:
              http://www.six4one.com/index.php?opt...fileinfo&id=38
              Just feed it the rgb values and it converts them to gamma 2.2.
              I can't find a download link for your app...
              • #22
                You have to be logged in for the DL link to appear.
