I noticed this once before... I think you might need to place the sky map in the enviromental override channel or the max enviroment channel or both, try it but it might not work.
with after fx it's possible, (for example with a png or tga file) when you import the file after fx tell you some options (or if it didn't just press ctrl+F on you pic in the after FX project window), and into that you have three option for the alpha : multiply, direct and "ignore" (or something like that my french version tell me "ignorer" ) if you check this option (ignore) your background apear and you can save it in other format like jpeg to put it behind your uncompressed file in photoshop...
That's really funny, 'cause I always put the VRaySky in a dome light since it gives better shadow casting than if you leave it in the environment, but there's no way that I can find to make the dome light visible and have a negative alpha (since we usually photoshop our skies). Maybe this would work better for you?
If you put the sky in a vray dome light and set it to visible it will render the sky with an opaque alpha, make sure "store with irradiance" is checked and it will work just like the env.
Shaun
yeah - i really want this feature... it's been asked for but guess it's not that straight forward...
I didn't notice that me an Shaun posted at the same time, I'd vote for an alpha override for the Dome too, I like the reflections but not at the cost of doing an extra alpha pass.
thank you for the tips guys.
@instinkt - sphere, visible to camera, with checked "matt" and alpha=1 options in vray properties become invisible to renderer but opaque in alpha. thank you
@RErender, ShaunDon - vraysky in vray dome light. I didn't tried this till now but really works. It will become my prefered method because I use dome light for lighting all the time. Thank you
I need this because Multimatrenderelements don't see opacity maps. I set objects with opacity maps in the material to alpha=-1 to get their masks. But the sky was problem till now.
Eureka! - found a way to remove the dome light from the alpha.....
Rerender - use camera clipping. Even with the far clipping range on the maximum value of 9999999, you get the illumination from the Dome Light, Objects reflecting the sky, and a lovely crisp alpha channel.....
I want my dome light sky visible to cam, reflect & create GI but no alpha. When I try far clipping the sky is no longer visible to the camera, just the same as when you make it invisble.
When you tried this ReRender & sv was the dome light map still visible to the camera and not the alpha?
Cheers,
Olly
Set V-Ray class properties en masse with the VMC script
Follow me for script updates: @ollyspolys
