Hedges using Pflow
  • Hedges using Pflow
    After searching the forums for a while (with no luck), I am resorting to asking the users if they know where a thread is, Recently I saw a thread that showed a technique where the user had a displaced box for the base of the hedge and a few scattered leaves over the top for a very realistic result. I think the example he showed were using text for the shape of the hedge. I found this one from TGraphics http://www.chaosgroup.com/forums/vbu...highlight=bush,
    but the one I'm thinking of was more recent and looked better (sorry Tgraphics).
    I thought the thread was started before July 7th so the recent forum crash shouldn't have affected it.
    Thanks,
    Bret
    Never mind, I just checked and it looks like it was posted in mid July so its toast.
    Bret
      Hi Bret - I posted the thread about the topiary hedge with particle flow and displacement. I will try and dig out the files and repost when i get the chance. Did you have any particle question?
      chris
      www.arc-media.co.uk
        Yes, please re-post. Cheers.
        "Why can't I build a dirigible with my mind?"
          Here is a tutorial about the process:
          http://www.orvatsel.com/max/hedges/
          3ds Max 2016/2021 (Vray 6.x), Windows 10 64bit , AMD 2990WX ThreadRipper 32/64 Cores, 128 gigs RAM , 2X RTX3090 48GB RAM
            Thanks, I use Parray for hedges quite often. However I would like to see the tutorial for doing hedges with Pflow.
              That would be great, thanks!
              Bret
                +1 Those hedges were amazing.
                b
                Brett Simms
                www.heavyartillery.com
                e: brett@heavyartillery.com
                  PHP Code:
                  global leaf_count 6000
                  global leaf_length 0.14
                  global leaf_width 0.06
                  global leaf_mat Multimaterial ()
                  leaf_mat.name "Leaf_material"
                  leaf_mat.materialList.count 2
                  leaf_mat
                  .material1 Standardmaterial ()
                  leaf_mat.material1.diffuseMap Bitmaptexture fileName:"Leaf_06C.jpg"
                  leaf_mat.material1.opacityMap Bitmaptexture fileName:"Leaf_06A.jpg"
                  leaf_mat.materialList[2] = Standardmaterial ()
                  leaf_mat.materialList[2].diffuseMap Bitmaptexture fileName:"Leaf_07C.jpg"
                  leaf_mat.materialList[2].opacityMap Bitmaptexture fileName:"Leaf_07A.jpg"
                  global leaf Plane realWorldMapSize:off name:"Leaf_01" length:leaf_length width:leaf_width widthseqs:1 lengthseqs:1 pos:[0,0,0isSelected:on
                  distr
                  pickObject prompt:"Select Object" count:#multiple
                  PF_Source X_Coord:20 Y_Coord:0 isSelected:on Enable_Particles:on Logo_Size:10 Emitter_Length:10 Emitter_Width:10 Emitter_Height:10 pos:[0,0,0
                  particleFlow.BeginEdit()
                  op1 Birth()
                  op1.Emit_Stop 0
                  op1
                  .Emit_Start 0
                  op1
                  .type 0
                  op1
                  .amount leaf_count
                  op2
                  Position_Object()
                  op2.Emitter_Objects distr --distributan array
                  op2.Use_Surface_Offset on
                  op2
                  .Surface_Offset_Minimum leaf_width/10
                  op2
                  .Surface_Offset_Maximum leaf_width
                  op3
                  Speed()
                  op3.speed 0
                  op4
                  Shape_Instance()
                  op4.Shape_Object leaf
                  op4
                  .variation 20
                  op5
                  Rotation()
                  op6 Material_Frequency()
                  op6.Assigned_Material leaf_mat
                  op7
                  DisplayParticles()
                  op7.color = $.wireColor
                  op7
                  .visible 20
                  op7
                  .type 6
                  op9
                  RenderParticles()
                  ev1 Event()
                  ev1.SetPViewLocation ($.X_Coord) ($.Y_Coord+100)
                  particleFlow.EndEdit()
                  ev1.AppendAction op1
                  ev1
                  .AppendAction op2
                  ev1
                  .AppendAction op3
                  ev1
                  .AppendAction op4
                  ev1
                  .AppendAction op5
                  ev1
                  .AppendAction op6
                  ev1
                  .AppendAction op7
                  $.AppendAction op9
                  $.AppendInitialActionList ev1
                  --particleFlow.openParticleView()
                  I have automated this thing a bit.. you may have to change the code a bit: - Changing the numbers of leafs
                  - Changing size (height / length)
                  - changing the diffuse map and opacity map
                  run the script, and select multiple objects and end with clicking the RMB.
                  www.cgtechniques.com | http://www.hdrlabs.com - home of hdri knowledge
                    huh? How do I use this code?
                    When I copy and paste it in a new script then run it, all I get is array undefined
                    Chris, any chance you can repost your work that was lost with that forum crash?
                    Kind Regards,
                    Morne
