Achieving Specular Highlights Indoors with natural lighting
  • Achieving Specular Highlights Indoors with natural lighting
    Have always been frustrated by not having Specular Highlights Indoors using the Vray SUN/SKY/PHYSCAM setup to get a very natural lighting.
    Specular Highlights only work when the first reflective bounce is hitting a direct light. Often most of a scene indoors is not in direct light so you don't get any specular highlight render element layer for doing quick & easy [& more realistic] highlight glows in post-production.
    See below for an image of the scene setup to achieve specular highlights indoors.
    Simply put a vray light [plane] in the window and check 'SKYLIGHT PORTAL'
    The GI - lighting from this light will be exactly as the Vray Sky behind it [Something I think that would be impossible to just GUESS??? which now seems obvious why this option was implimented]
    You should now have nice speculars indoors!!
    Cheers
    Cool, thanks for the trick!
    Tim Nelson
    timnelson3d.com
      whats the difference in render times between the two?
      Chris Jackson
      Shiftmedia
      www.shiftmedia.sydney
        I haven't had a chance to compare render times yet, [I was only testing the quality so far] although with the small test scene I used didn't seem to add any extra render time.
        I will test again soon when time permits
        cheers
