3gb "switch" in Windows 7 32bit
  • 3gb "switch" in Windows 7 32bit
    For those of you with say 4gb of ram, 32 bit Windows 7 and "Out of memory" issues when rendering:
    1) Shift + right-click folder c:/windows/system32 , select "open command window here" or something like that...
    2) run command like this: BCDEDIT.EXE /Set IncreaseUserVa 3072
    Use at own risk!
    It solved most of my problems, although windows itself can be a bit slower. You could just repeat the command with 2048 as the value to restore default settings when you don't have to render anything big.
    TeH
    i wish it was that easy with xp32 hehe
