Spherical harmonics tutorial
  • Spherical harmonics tutorial
    Hello guys,
    We've added a short tutorial on spherical harmonics here: http://www.spot3d.com/vray/help/maya...s_sph_harm.htm
    What is the advantage of SPH baking over traditional baking?
      The advantage is that you can change the envronment map with a completely different texture, or add/move directional lights and the color bleeding will be automatically readjusted from the spherical harmonics - you don't need to redo the baking process.
        Hi, vlado,
        Thank you and the team to implement this into Vray and the tutorial.
        I have couple questions:
        1. What is the intention behind baking Spherical Harmonics to the .xml for parsing in a foreign application? Interactive relighting?
        2. Can one use the .xml file in ex. Nuke to achieve SH-based lighting and how?
        Thanks,
        Json
        always curious...
          Once the spherical harmonics are exported to a .xml file, they can be converted relatively easily to various formats as required by game engines and other interactive applications.
          I haven't looked into the Nuke spherical harmonics yet; while it is probably possible to use the spherical harmonics data, it is unlikely that you can use the .xml file directly. Should not be too hard to convert it though - will look into it.
            Thanks for the reply, vlado.
            I believe Vray is interested in the VFX market too as more companies have adopted it.
            It would be great to see Vray being connected closer to Nuke through Katana or direct implementation like the AtomKraft (http://www.jupiter-jazz.com/atomkraft) such that one can do relighting, lighting, or even look-dev inside of Nuke.
            cheers,
            Jason
            always curious...
              Jeees.. Atomkraft looks interesting indeed!
                Mind you there was also an announcement for 6.2 wich seems to have the first steps towards integrating some Katana tech....starting with integrating Renderman complient renderers. We'll see
                  Nice! Standalone parser for nuke - sounds very cool.
                  I just can't seem to trust myself
                  So what chance does that leave, for anyone else?
                  CG Artist
                    Thanks for the tutorial documentation.
