tutorial for vrayambientLight +VrayDirt
  • tutorial for vrayambientLight +VrayDirt
    Hi Guy does anyone knows about a good tutorial tu get around this VrayAmbientLight + VrayDirt on exterior scenes.
    I need to do an exterior animation and would like to avoid GI all this pre-calculating of IRRmap
    thank.
    this is for posting tut's, not requesting them
    Kind Regards,
    Morne
      It should be fairly simple, just put the ambient light there, add a VRayDirt texture in it and adjust the dirt radius to get the effect you need. You may want to turn on the "environment occlusion" option so that the VRaySky or other environment texture is taken into consideration.
        thanks vlado, just did my first animation render with vraydirt... it's easyer than i was thinking...
        just had my displacement grass flycking and noisying, but will do some other tests
          3DATS published something with a MAX file awhile back.
          Bobby Parker
          www.bobby-parker.com
          e-mail: info@bobby-parker.com
          phone: 2188206812
          My current hardware setup:
          • Ryzen 9 5900x CPU
          • 128gb Vengeance RGB Pro RAM
          • NVIDIA GeForce RTX 4090
          • ​Windows 11 Pro
            Hi Vlado - I'm just messing about with this. When I tick on 'environment occlusion' in the VRayDirt map, my render completely blows out. I am using a vraycamera, vraysun and vraysky in the environment slot. The only other light is the vrayambientlight with this vraydirt map in there. Any ideas what I am doing wrong?
            Kind Regards,
            Richard Birket
            http://www.blinkimage.com
              Do you still have the sun turned on / lighting the scene? Then you have double light for the sun. The sun itself and the ambient light using vray environment (sun included).
              Lasse Kilpia
              VFX Artist
              Post Control Helsinki
                Yep, I have the sun turned on still as I want it to create the directional sun lighting. Are you saying that the AmbientLight is also using the vraysun?
                Kind Regards,
                Richard Birket
                  I thought that you would like to get ambient only from the vray environment.
                  Just tested the setup with sun + ambient light + vray env. and yes , it burns everything totally.
                  I didn't found away to control it to get any good balance between them.
                  Hmm... so I'd like to know the right way of doing it also.
                  Lasse Kilpia
                  VFX Artist
                    I'm sure there should be a simple solution to this. At the moment, I have reduced the value of the lightmap to 4 (from default 100) and this seems to look much better and still picks up the environment colours. I don't know if this is a workaround hack or the correct way to do it though.
                    Kind Regards,
                    Richard Birket
