suurlands beetle rendering
  • suurlands beetle rendering
    does anyone know how the setup for suurland beetle rendering is?
    tried some things with hdr and the sphere he described in the making of.
    could not do it with vray..
    any suggestions??
    regards
    s.wolf
    sphere? well. he did render it in vray. so it should work. maybe its just your materials that are wrong
      as a former fr user i know how to exclude something from the msp tree.
      but i could not figure it ou how to do with vray. hdr for lighing and reflecting, a sphere for diffuse shadow and background...
      regards
      s.wolf
        he used an inverted sphere for a skylight when he rendered it in fR i believe. dont need to do that in vray
          Did he use vray for that render? You talking about the black beetle? Thought he used fR.
            i am talking about the green beetle, i think he used the same technique in vray. the black one is fr.
            regards
            s.wolf
              Not sure either, but thesphere technique used in fR was to overcome some of the issues that you have when rendering HDRI environments. Those are not issues in Vray, and I believe that he might have simply used a regular envionment light, either via and envionment map, or via the environment overwrite in the rendering dialogue box.
                yeah. stage-0 was not good for skylight and a sphere technique was needed. the black is fR the green is vray
                  i think the sphere was used to get this soft gradient background with shadows on the floor. the hdri was used for reflections and lighting.
                  but how do i exclude the sphere from the hdri lighing?
                  regards
                  s.wolf
                    simple...dont use a sphere. just have a white background or gradient or whatever you want. use a plane for the ground and make that a matte shadow properties. then put your hdri into your skylight and reflection slot.
                      worked!!
                      thx elf, tried for hours, but now its fine!
                      regards
                      s.wolf
