glas
  • glas
    hi all!
    when i render glas with a thickness like a glas plate for a table, i can not achieve the look i want.
    f.e. the egdes of the glas and the faces on the small side of the glas are supposed to be much darker than the upper and lower faces..
    a glas plate 1x1X0.02 m the 0.02m part should be totaly non transparent.
    i tried some settings with vray, but can not get it to work..
    regards
    s.wolf
    Post an image stephan
    and your settings
    Natty
    Natty
    http://www.rendertime.co.uk
      Usualy the real glass with 2cm thickess is frosted in those faces, did you already try?
      I think it should do the trick
      Gonçalo
        i would love to but yahoos photo album is down...
        regards
        s.wolf
          @goncalo:
          do you mean i have to put a other material on that faces?
          i tried to avoid that..
          regards
          s.wolf
            regards
            s.wolf
            Use Psy's FTP instead:
            here's the ftp info and plz make a folder of your username.
            Domain: ftp.3dmaxedout.com
            Username: vray@3dmaxedout.com
            Pasword: govray
            look at http://vray.3dmaxedout.com/ for the file after its uploaded.
            Torgeir Holm | www.netronfilm.com
              tried..
              but it does not accept the pasword..
              what is wrong?
              regards
              s.wolf
                Try again with a different FTP client, it works from here..
                  may be some problems with our firwall. admin is at home of course..
                  anyway.. is it so hard to figure out the problem with the glas without images?
                  regards
                  s.wolf
                    So what are your glass settings?
                    Gonçalo
                      just one of the glas materials from the vray matlib..
                      clear glas f.e.
                      applied to a box 1x1x0.02m
                      render...
                      regards
                      s.wolf
                        Man this doesnt help, I cant guess what is your problem...
                        Gonçalo
                          sorry...
                          can´t upload a picture, yahoo is down..
                          does anybody know how to upload images to the internet?
                          regards
                          s.wolf
                            hope this works...
                            http://www.pixum.de/viewalbum/?id=880404
                            regards
                            s.wolf
                            • #15
                              Try to add a fog color like RGB 160,195,177 and increase the multiplier to 0.5
                              Gonçalo
