How to deactivate rendering while calculating irradiance map
  • How to deactivate rendering while calculating irradiance map
    Hi there beloved forum !
    I've been said to try it in another forum, so here's my second try :
    This is maybe a very very stupid question due to blindness or lack of knowledge but how can I disable the rendering of pictures when just precalculating the irradiance map for an animation ?
    Is it possible or not, and when, where ?
    If it's not, what settings do you use to increase the speed of rendering to avoid the unnecessary process of rendering the useless pic ?
    Thanks a lot in advance.
    ____________________
    www.formfest.de
    There is a "Dont render final image" switch in the global switches section of the latest Vray Advanced version.
    You can also try setting your Image Sampler to Adaptive -4,-4 or less.
    Hope this helps.
    Brian
      Or use region rendering and set a very small region. Vray will calculate GI for the whole image, not only for the region. So you'll have IR info and only need to render for example 5*5 pixels!
