Difuse Map 100% in Glass 10%, How?
  • Difuse Map 100% in Glass 10%, How?
    Thats the question
    I cant acomplish a simple trick. I want a Glass material to have some grapichs printed on but my grapichs are transparenting (word invention 2.0v ) with the material.
    I use a 10% refraction and a bitmap with the grapichs in the difuse slot.
    Any Idear?
    I solved it using the same map in the reflectance map in alpha mode, but I`m filling doing it in the wrong way, It must be a magical trick :P
      have a look at the exterior sample scene from osmosis..
      the glas has some dirt in it. maybe it works out for you..
      regards
      s.wolf
        I use simple trick. object with extrude less then glass and with material: bitmaps in diffuse and refract slots, IOR=1. But sure must be simpler way.
