BLUE skie
  • BLUE skie
    Hiii everyone,
    First of all, its a pleasure being here, wrinting and learning.
    Hey, i would like to know where can i find a GOOD skie to use. I often have used hdri skies, but they seems to be not so realistics. I found some 360 skies (?) but i cant get it right positioned: the skies that i have found in maxwell warehouse for example, have just the skie, as oposite as my hdris that are full (skie + ground). Can you understand? My questions: how can i set those kind of skies correctly???
    How do you work with this? HDRIS? PostProduction?
    Re: BLUE skie
    Hey there,
    if you just got the upper hemisphere as a file, you could set the vertical repeat value to 2 and use an infinite groundplane.
    Alternatively, you could merge a new sky into an existing background image using Photoshop or the like.
    Adding background in post production is always risky business - unless you set the reflexion mapping right.
    Hope this helps a bit to get further thoughts started
    Cheers,
    Matt
      Re: BLUE skie
      Matthias? How it is going?
      How do you think of chat? We could change good ideias!
        Re: BLUE skie
        Chat?
        Oh boy, work has me tight these days... send me a PM and I'll answer as soon as I get the chance
        Cheers,
        Matt
