COMPLETE RENDER PROCESS TUTORIAL
  • #31
    Re: COMPLETE RENDER PROCESS TUTORIAL for new users
    For some reason i am not able to download the third file. It says that it is deleted because of the content or by the owner.
    This is the one i am talking about:
    3.- ILLUMINATION PART 2
    http://hotfile.com/dl/86838171/a3840...ART_2.wmv.html
    Ps. I have made a lot of tutorials (all in dutch) especially for sketchup and a few weeks ago i have learned a few of my fellow classmates how it works. (for now i am still the best) So i will maybe try to turn some of mine tutorials into english. I do think it could help a lot of people. Like you said in your tutorial that it is very important for people to understand how to setup the settings of v-ray. With the new version some options work quite different and i must say that this makes it sometimes hard to get the same result. But if you see someone else doing it you always learn faster than that you have to find out yourself!
    Dutch tutorials for Sketchup and V-ray: Proseduction.nl<br /><br />And although i have some tutorials i still am learning!
    • #32
      totally agree with you proseduction.
      you don't have to download the videos anymore, you can watch them online here:
      http://software.asgvis.com/index.php?option=com_content&view=article&id=888&I temid=53&utm_source=Publicaster&utm_medium=email&u tm_campaign=ASGVIS%20News:%20The%20complete%20V-Ray%20rendering%20process&utm_term=See+all+videos+ in+the+%22V-Ray+From+Start+To+Finish%22+series+now!%0d+
      los campeones no nacen, se hacen...
      • #33
        arqestevez , Can you give me the site to download maps hdri
        There are two types of hdri one to make in GI and other one in BG
        for environment thanks
        • #34
          sure...
          just wait till the thumbnails load and then just download anyone you like
          http://www.hdrlabs.com/sibl/archive.html
          • #35
            Dear Arq. Stevez I have a great problem with the render when I import a HDRI image, when I click render after pass some seconds v-ray send me a message that says error an then other that say somthing like culdn,t create an error repot and there's no enought space in my temp folder. I really apreciate if you can give me some tip to solve this problem I cant send you the scene if's necesary. I'm alway form Mexico and i like to contact you for some support, my mail is licuid18@hotmail.com and quincunce_arq@hotmail.com. Le agradezco de antemano Atte Arq. Ramiro Herrera Oaxaca Mexico
            • #36
              Que tal Arq.Ramiro...
              bueno, el mensaje significa que tienes que ya no tienes espacio en la carpeta de los archivos temporales y tienes que borrarlos, pero no son los archivos temporales de internet, están en disco c... De vez en cuando también importamos algún material que nos causa que el programa reviente, hay que checarlos todos, o cuando un archivo es demasiado pesado. en mi caso, yo empiezo a tener problemas cuando supero los 250 mb por archivo...pero en este caso si son los archivos temporales, hay que buscarlos y borrarlos.
              saludos!
              Arq. Omar Estevez
              • #37
                Holla Arqestevez
                Hoje, creio que nem sempre se trata da localização dos materiais existentes no ficheiro Skp,...mas sim de alguns outros que porventura serão mais antigos e serão agora incompatíveis, dado que no teu projecto "Complete Render Process" consegui renderiza-lo sem problema algum e não tive de checar nada....
                Contudo se forem checados não se correm riscos novamente, e o melhor será cópiar exactamente todos os materiais que se encontram no "temp folder" e reconfigura-los novamente o seu caminho no "Material Editor" como bem referiste.
                Cumprimentos
                Castro
                Intel(R) Core(TM) i7 975 Extreme Edit. 3.33GHz / 6.4GT/s 8Mb box / Motherboard Gigabyte GA-EX58-UDS / Asus GForce GTX275HDMI 896DD3 (12Gb) / Windows 7- 64bit / Sketchup 2013 / V-Ray
                • #38
                  jeje... what?? ;D
                  i just understood something about existing materials ans sketchup hehe ;D
                  • #39
                    Originally posted by arqestevez1
                    jeje... what?? ;D
                    ;D ;D ;D ;D
                    Attempt to translation:
                    "Today, I believe that this is not always in the location of materials in the Skp file, ... but some the others materials who may be older and are now incompatible, since in your project "Complete Surrender Process" i could render it without and have not had any trouble or checking anything....
                    However if they are checked dont run risk again, and the best will be copy exactly all materials they are in the "temp folder" and reconfigures the new paths of material in the "Material Editor " as you as well mentioned."
                    PS: hehehee .... I understand perfectly what you write, happily for we (Portuguese), we have some easiness to understand the Spanish Language ...but of fact it is a case for think, will be that the others also will not will have difficulty to perceiving :-\
                    Saludos
                    Castro
                    • #40
                      hehe, once i talked to a brasilian in a competition in new york, and it's just a matter of practice... at first i was not capable of understanding anything, but our languages are very similar actually
                      • #41
                        Arquitecto Stevez le agradezco su asistencia y su pronta respuesta. Procedo a borrar los temps así como a checar los materiales y le informo mis progresos. Buscare algun tuto para subir las imagenes por que ni idea, soy un novato en esto, pero si no como sea si no es mucho abuso las mando a su correo.
                        Gracias totales y Saludos.
                        • #42
                          In the videos i recomended some Photoshop tutorials, but i didn't tell you where to download them from...
                          well, you can find them here...
                          http://www.photoshoptopsecret.com/
                          there are 4 dvd's. and what they teach you does not have anything to do with renders, but you learn a lot, by making movie posters, etc... and in the end, you can use all the stuff and tools that you learned for your renders.
                          really great tutorials. totally recomend them
                          see you around.
                          Arq. Omar Estevez
                          • #43
                            Re: COMPLETE RENDER PROCESS TUTORIAL (PHOTOSHOP TUTORIALS LINK at the end)
                            hohoho, i had not seen this trailer
                            http://www.photoshoptopsecret.com/sp...sptrailer.html
                            terrific stuff... for the photoshop tutorials.
                            really hope this motivates you to improve your skills and share the few or much that you know. it's all usefull, and there's always time ;D
                            • #44
                              thanks a lot omar ..
                              nice tutorial ...
                              really it was helpful for me
                              and here is my try on a model from google 3d warehouse with some changes on furniture and materials >>
                              the first one is the original one while the other one is edited with photoshop ..
                              Small and Humble ... Full with Ambition ! <br /><br />&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; Ele©t®σn
                              • #45
                                well, it's nice to see that the tutorials actually help.
                                electren, it's a very nice work.
                                i think you could improve it a little if you make just a couple of things.
                                first, play a little bit with detail enhacement in the vray options, or use the smart sharpen tool on photoshop
                                and you have to move the background image... righ now, your image looks like this:
                                correct that, and you will have a terrific image.
                                see you around
