DOF with physical cam
  • DOF with physical cam
    Hello everyone
    I am having problem with the dof and physical cam...
    Could someone explain how I can achieve the same DOF as with the default cam?
    Does the DOF with physical cam work in meters) Does it have to be in milieters?
    Thanks
    In a real camera the DOF is controled by the F-Number, the same thing happen in V-Ray. The F-Number control the DOF, but you have to keep in mind that the F-Number also control the exposure. SO the idea is to keep the EV when you are working with DOF and physical camera. Lower F-Number produce more DOF effect while larger number produce less DOF.
    I found the following tutorial very useful to explain what I'm saying. It is for 3ds Max, but the same concept apply to Rhino.
    http://www.cg-blog.com/index.php/201...d-dof-vray.htm
    Best
      Thanks, I understand better now...
