VRay Automator - first update available
  • VRay Automator - first update available
    New in v0.2:
    Added option to perform property change on selected objects only.
    Turned the script into a MacroScript for easier integration in the Max UI.
    You can get it here:
    http://www.metinseven.com/menu_goodies.htm
    Cheers,
    Metin
    Sevensheaven.nl — design | illustration | visualization | cartoons | animation
    It's a good start..
    But my problem is I use different subdivs values, so a second set of controls where you could multiply the current value would be nice. Ofcourse there is a problem that it only takes whole numbers, but I'll let you solve that :P
    /Thomas
    www.suurland.com
    www.cg-source.com
    www.hdri-locations.com
      Heya Thomas,
      I'll see what I can do. I'm currently adding more properties first, and a "Do it all at once" button.
        Thanks Metin !!
        i try this later
        good week-end
        Vince
        Architecture & design Sàrl
        global solution for architecture
        www.architecture-design.ch
          Thanks, y'all have a good weekend. A new version of The Vray Automator will be up tonight.
          Cheerio,
          M7
            If you reload this page, the screenshot above will show you a screenshot of the fresh version 0.3, to be fetched at MetinSeven.com.
              Updates are released faster than I can post the news here. Check out this thread:
              http://www.chaoticdimension.com/foru...asc&highlight=
              Cheers,
              M7
