ok .. u open vray environment then max environment?
then u don't use max environment
i guess is 1 step in + ... there is no need for that ... pretty sure that HDRI map will not be use as a visible background
or is trick i don't know
well..hmm... overriding max BG is ok, but why using the same map for both ..vray and max?
One advantage would be to use a hires JPG for the BG (which is visible in the rendering) and a lowres HDR for lighting.
btw,
have a look at the SDR-Project Forum, where we offer a (max/lw)script for loading different enviroments with one mouseclick the way i wrote before
Thanks for the tutorial mate. But i have problem, how can i make that hdri map affects in objects and materials i have in scene? I mean i want my objects reflect that hdri.
Im trying to make this thing work .. but the file that I download never works.. it always says.. "unable to find a suitable codec (vids:div4) to compress the video stream.. you will not be able to view the movie"
Hmmmm... Ive tried it on both computers and still am having problems.. I know that it works because I remember downloading it on my friends puter...and it worked there...
